Captain Jeff
Thread starter- Joined
- Jun 15, 2005
- 159
Hi, My 1999 Johnson 115 (60deg V4) loses fuel prime when not in use and is difficult to re-prime. If the boat is not used for a day, or possibly even hours, you will need to pump the primer bulb and it is difficult to get a good prime. I can hear air bubbles going through the bulb while pumping and the bulb never truly gets firm, only slightly firmer than it was. I can also see some air bubbles in the clear plastic fuel/oil connector where the fuel line connects to the engine.
When running, sometimes it will run great, other times it won't. Last night it would run okay under around 2,000 RPM and sometimes bog and want to stall. Pulling it back to idle would keep it from stalling. If I was able to get it on plane, it would run okay at higher RPM.
I have replaced the 3/8" fuel line from the tank to the water separating fuel filter all the way to the engine. I also have tried two brand new primer bulbs. No fuel leaks out inside the engine compartment when I pump the primer and I can usually hear the air releasing from what I imagine is the vapor separator. I am pretty confident there are no leaks in the fuel line to the engine. It seems like something is going on in the engine (i.e. air leaking back into fuel supply) that is causing it to lose prime. Your help is appreciated.
