1999 Johnson 115 Excessive Smoke at Startup
Captain Jeff
Last season I replaced the VRO/OMS pump, rebuilt all 4 carbs, rebuilt the primer solenoid and vapor separator tank. I also did a link and sync.
I usually take the boat out once or twice a week. I pump the primer bulb 3-4 times to get it firm. The boat starts right up but smokes a good amount. It will continue smoking until I pull away from the dock and accelerate a bit. If I idle it at the dock for 5 minutes, it seems to gradually smoke less but it is hard to say. The smoke is a bluish white.
The good news is that the motor runs great besides the smoke. It runs smooth, doesn't stall and has good acceleration. I have been using Pennzoil Marine XLF (Extended Life Formula Synthetic Blend) TC-W3 oil for the past couple years. I leave the oil tank cap loose because I don't trust the vent on it.
Any ideas? Thank you
oldboat1
sounds like it runs a little rich at idle when cold-starting. You might try adjusting the needles (2?) slightly leaner -- clockwise -- to see if there is less smoking. If cold starting is more difficult with the leaner setting, I think I would set it back to a richer setting and live with some smoke at start up.
If the primer setting is not in the running position, there would also be a smoking issue (similar to leaving a choke closed or partially closed). I don't see a primer solenoid for the '99 carb models, though -- might be looking at the wrong diagram. What is your model number?
A 1999 carbureted 115 has a primer solenoid.----Plain as day on the " fuel bracket " parts list.
Captain Jeff
Thanks guys, I hope that is it. I thought I had it in the run position but may have nudged it when installing the air silencer or working on the engine. I'll check next time I am at the boat.
Captain Jeff
Well, the red lever was in the down position already. But I think I found the issue, just not the exact cause... When I pump the primer bulb on the fuel line, I can feel it get harder and hear some air venting by the vapor separator. However, when I look at the sight glass/fuel nipple where the fuel and oil lines come into the lower engine cover, I can see a good amount of air in the fuel line even after the bulb gets hard.
I am wondering if the motor is running at a very rich oil mixture at startup since the VRO may not be pumping adequate fuel for the amount of oil it is pumping. Then, once I get underway and the VRO gets a better prime, it is able to pump adequate fuel and the mix turns to the correct fuel/oil mix. I don't know how air is getting in the fuel line though. Any thoughts? Thank you
Chris1956
When the boats sits between runs, the gasoline in the 50::1 fuel mix in the carbs evaporates. This causes an oil rich mix to be in the carbs, when you first start up.
Captain Jeff
Thanks Chris, good point. Any idea about the air in the fuel line? I store the motor tilted our of the water. Maybe the floats drop as fuel evaporates and air gets in through the seats?
Would this extra smoke on start-up have anything to do with the recirculation system ??-----As you know oil drains off the parts to collect in the bottom of the cylinder crankcases,----Then on start-up this oil is put back in the cycle.----The extra smoke tells the experienced operator that all is in fact NORMAL.
Captain Jeff
I have had this motor for 12+ years and it never smoked this much on startup, that is why I was concerned. It is pretty heavy smoke and lasts for minutes. I'll try taking a video next time.
