basstracker2008
Thread starter- Joined
- Jan 20, 2008
- 39
To all who has the patience to deal with a first time boater...
Below is what I did to test compression.
It describes the results and issues I encountered:
1. Run the engine to warm up. Turn off engine.
2. Remove the first spark plug and replace it with compression gauge.
3. Crank the engine.
4. The reading is 125 PSI.
5. Now when I moved to the next spark plug (bottom). I realized I have no enough room or space to insert my compression gauge.
As you can see above It is obvious that I need a detailed procedure on how to test, what results to expect and what tester is available to test the lower spark plug. See attached 2 pictures to see what I'm talking about.
http://i254.photobucket.com/albums/hh92/greatyear2008/DSC07432.jpg
http://i254.photobucket.com/albums/hh92/greatyear2008/DSC07434.jpg
