1999 Force 120
peaser
I recently purchased a 1999 Fisher F18 FS/ with a Force 120. The hull and engine have less than 200 hrs. total and are in great shape. I had the engine serviced (new water pump kit and impeller along with compression check, 150psi across the board) and recieved a clean bill of health. The mechanic thinks that the engine was never serviced prior to this.
At WOT it gets 43mphchecked to GPS( with 5100rpms) at 5100rpm's and the boat planes quickly.
This is my first boat and I was wondering if there is anything else that I need to do.
roscoe
Re: 1999 Force 120
Change the lower unit lube.
Decarb is in order.
This is recommended by the manufacturer every year.
