1999 ficht 115- no high speed power?
Hemibeep
I have a 99 ficht 115. 46 hours use. Fresh indexed plugs. New fuel. No trouble codes. Was sitting for several years. I was able to get it to plane one time, then lost power. Ideals fine and will run nice at low speed. It does have the jet drive, and I had to remove carbon from the exhaust probe (was setting code)
It acts like it is out of fuel to accelerate. Any thoughts? Thanks
jimmbo
Clogged fuel filters, fuel lines, ruptured diaphragm in fuel pumps. Fouled sparkplugs. Do a compression check, the FICHT engines were famous for scored cylinders, broken rings, mainly on the 150 -175s. The V4s weren't as bad but...
You really need to access the ECM to see what is happening. It could be a bad temp sensor, there were a couple of them for water and intake air.
ondarvr
First make sure the reverse gate on the pump is adjusted correctly, if the gate isn't adjusted correctly it can move and partially cover the pump nozzle as the RPMs and pressure increases. If this happens it feels like the motor is down on power and won't plane.
boobie
Agree with the above. First thing to check on a jet when down on power.
Hemibeep
I will check on gate. I do have the software and checked all sensors. No current codes. The motor just does not seem to increase rpm, except for the first time after I cleared carbon from the exhaust probe. That probe is still clear. Temps seem okay.
Is there a kit to rebuild fuel pump diaphragm? I thought it was fuel and vapor separator combo? I did replace fuel lines and new fuel filter.
Thank you.
Hemibeep
The gate was out of adjustment and could part or the issue. Perhaps the gate blocking water flow created backpressure limiting RPM?
Thanks for the tip!!
Hemibeep
Thank you for the advice. It was the gate in partial open position. Cannot believe I did not catch that. Runs great!
Thanks'again!
ondarvr
Thanks for the update.
​Always nice to have an easy no-cost fix.
topspeed1
Can someone explain the gate to me? I have a 175 ficht that will not plain but it runs good and idles good.
