1999 Evinrude J130PLEED leaking from carburetors
rimiki
1999 Evinrude J130PLEED leaking from carburetors on a 1999 sprint deck boat. The boat has an electric fuel pump. I'm a little confused. HELP!!
flyingscott
Need more information does it do it while it is running. Does the fuel pump keep running when the motor is turned off. Does it happen when u tilt the motor or all the time. Your motor is not supposed to have an electric fuel pump.
rimiki
The boat has a battery disconnect as soon as you turn it on the pump is running and runs until it is off.
flyingscott
Ok so the pump is attached to the ignition. Is the boat new to you, it can be normal for some gas to drip out of the carb. It could also be a bad needle valve or float adjustment or the fuel pump is overwhelming the carbs.
