I've appreciated everything I've read and learned on this site, and tried to use it to diagnose my problem. I have also called several local evinrude mechanics, I own the full service manual, and now own the software to help me diagnose codes, and test different aspects of this engine. I bought a pair of 1999 Evinrude Ficht 225 hp June 2016, hanging on the back of a very well maintained 1989 Whaler Full Cabin original owner. On the third weekend owning and running it one engine died about 20 miles from home with my wife and one year old aboard. Safe ride home on one engine. Tried to figure out the fuel problem, ended up needing a fuel pump, reprogrammed emm and the dealer told me he wouldn't work on the engine until I put new fuel rails on both engines. $3,444 later...used the boat for the rest of the season, winterized in october, went to start last week, port engine ( the one that got serviced) will not start. So far...Engine hours 652, no error codes, fuel pump comes on and cycles, spark tested on all 6 cylinders and functions, fuel injectors fire on each cylinder (tested separately), no fuel found in cylinders though, spark plugs dry. Good compression on all 6 cylinders. I can't test fuel pressure because the evinrude mechanic removed the fuel rails that had the shrader valve on it. Might be air trapped in the fuel system, but on all the forums nobody seemed to finish how to purge the air out of the fuel system. I tried removing a spark plug and using the software to fire that injector after cycling the fuel pump, but no fuel came out. I tried disconnecting the top of the fuel pump and running fuel out of the system using a loose fuel line and a bucket. The fuel came out pretty steady, but occasionally with bubbles. No fuel found under any of the spark plugs whether testing with the computer or turning the engine over. I topped off the in engine fuel water separator. When I first tested the compression there was fuel in cylinder 4.
My Question:
Is there another place to bleed air out of the fuel system to create clean fuel pressure at the injectors with no air? Any other thoughts as to why the fuel injectors aren't picking up the fuel? I know there is some fuel in the rails because it comes out when I disconnect, I just am not positive all the air is out, or the fuel pressure is high enough (new fuel pump 6 months ago).
UGH I've owned Mercs, Mariners, Suzukis, JohnSukis, Johnsons, and Hondas...but never have I had so much trouble with one engine in a short period of time...FICHTH8ER.
My Question:
