I have a 1999 Evinrude 150 HP FICHT ? E150FPXEEN
I recently experienced engine trouble which turned out to be a disconnected spark pug cable at the ignition coil. While working this issue I did the following
The engine ran fine after this work, then I used a can of Evinrude engine tuner and replaced the spark plug wires.
I then test drove the engine up to 4000 RPM and it ran better than it ever has.
I took it out the next day and it ran good but about 3 hours into the trip it started running rough at low RPMs and at idle. It ran good at higher RPM?s
Back at the dock when I started the motor, it would start 1[SUP]st[/SUP] crank and idle normally for about 5 seconds, at which time it would surge to about 1100 rpms and stay there. The RPM would fluctuate from about 800-1200 RPM and occasionally return to normal idle speed.
I am thinking that I have a fuel leak, which is causing extra fuel to enter the cylinder.
I think it could be the fuel lift pump, fuel pump or an injector.
Do you have any advice? I don?t want to rebuild or buy a new fuel injector unless I can verify that it is the problem.
I have the diagnostic software but I am not sure what test would need to be run to isolate the issue.
- Drained the fuel system and pumped the fuel tank dry
- Cleaned all fuel system components (sending unit, separator block, pickup etc)
- Replaced all fuel lines TO the engine with premium A1 grade
- Replaced, gapped and indexed all spark plugs
