1999 evinrude ficht 115hp
lktofsh
Aware of all the issues with these engines. Have just picked up boat from the repair shop for a very persistent problem of a midrange mis. Mechanic changed plugs to champion QC12PEP per TSB. But does not know if this will fix, guess he thought I had money burning hole in my pocket. I have changed fuel fillter and thermostats, use XD50 oil and 2+4 fuel conditioner. Diagnostics show OK and no water in fuel. Motor starts and runs good otherwise. Any ideas? Thank you.
DHPMARINE
Re: 1999 evinrude ficht 115hp
How does it run since the service that cost so much?Maybe tell us more about midrange mis ??
DHP
lktofsh
Thank you for responding. the mis seems to be in the 2 3000 rpm range.It happens consistently no matter the load. Diagnostics shows no code and all seems ok otherwise.Motor is on a 17ft. princecraft boat and has low hours.Prop is the OMC SST 13 7/8x17. Also shop confirmed no water in fuel either.
DHPMARINE
Wow ! Could be almost anywhere.I'd lean towards a spark problem,but you might try pumping the primer bulb when it happens.Look at all wire connections,starting with the star washers at the battery terminals,Also be sure a primary wire hasn't loosened @ a coil tower.Maybe even run in the dark,and look for any arcing.
Good Luck,
DHP
zzzzz
I would also lean towards electrical connections...the smarter the motor the fussier they are about good,clean,tight connections8)
noelm
Hey do not listen to all the "reports" about Ficht engines, the V4 Ficht will give you many years of reliable running, the early V6 had some dramas ,but your 115 is a good motor, trust me on this one!
lktofsh
Thanks for all the good advice. I will now have to wait for warm weather to dive into this problem further. As for the ficht V-4 I had a conversation with a local dealer who did mention these were good motors and the bulk of the problems were with the 150's and up.
grouperguy1
Can you help me with diagnostics ? I have cable, software, ibm thinkpad and get to the screen shown on page 11 of the users guide ficht diagnostics sofwtare version 1.42b. I have tested and confirmed com2 as operational on my laptop and rang the cable to confirm continuity ???
pete s.
I am looking at purchasing a boat with a 1999 115 hp Evinrude Ficht. Was this a good motor or one prone to problems.
Thanks!!!
catalinated
Hi did the QC plugs help any? I have a 1999 115 Evinrude Ficht that I just bought. It is also missing in the 2000-3000 range. I was looking at the XC12PEPB which is recommended for year model 2000+ 115hp ficht engines and thought it might help (currently I have the 7712 which is recommend). Please let me know if you've had any luck with the new plugs or anything you think might help me. Thanks in advance.
tx1961whaler
Those guys have not posted here in 2 or 3 years.......
Welcome to iboats!
Next time, please make a new post instead of dragging up an old one and tacking on to it. It keeps things less confusing and you are much more likely to get a reply......
