1999 Evinrude Ficht 115 engine air flow restriction
Chevelle Freak
My 1999 Evinrude Ficht 115 engine runs perfectly with the hood/cowl off and runs perfectly with the side cover off (i.e. cover where the fuel lines, etc. enter the engine); however, it has a significant loss in power with both of the covers on. A reputable outboard mechanic has checked everything that he can think of (i.e. fuel pressure, computer diagnostics, etc.) and cannot find the problem.
With both covers on the engine runs for a few moments correctly, then begins losing power in a turn (RPM's go from 5500 down to 4000 or less). When you shut off the engine for a couple of minutes, it restarts and runs great for a few minutes until it loses power again. I think that it is possible that there is some type of air filter or other material that is getting sucked shut and shutting off the air flow; however, I don't know where to look.
I understand that the air silencer has a screen mesh to prevent large objects from entering it (and mine is not clogged); however, I am wondering where the air enters the underhood compartment.
Any ideas? Thanks. Rian
emdsapmgr
Looks like that engine ingests most of it's air through the air vent at the front of the cowl. Have you disassembled that 2-pc. vent to be sure it is clear of debris? If it was ever stored in a barn, you'd be surprised what might wind up in that small space.... A different example: We had a customer come in with a duck hunting boat. 25 tiller engine. Would not run with the cowling on. We found that the customer's application of a camouflage decal had completely closed off all the cowling air intakes. A handy pocket knife fixed the problem.
Chevelle Freak
Thank you very much. I wasn't sure where the air entered the cowl and hadn't noticed the air vent at the front of the cowl. I'll check it out!
Chevelle Freak
Well, I checked the baffle that is mounted to the front of the cowl/hood and found that it was not clogged at all. Any additional ideas as to why I have restricted air flow would be much appreciated. Thanks.
