1999 Evinrude 175 Ficht
mtlendy
I am looking at buying a boat that has a 1999 Evinrude 175 Ficht motor on it. Been reading a lot and see in the older post about these motors & the problems they had & just wondering if problems were ironed out with them and what peoples opinions are as if they would steer clear of them. This is my first big purchase on a boat so just want to get it right the first time. Thanks in advance for the postings.
Evinrude57
There were problems with these engines, but it was mostly an instance were you either got a good one or not. I was also the dawn of the Direct Injection ara of 2 stroke outboards and they suffered from a lot of people not knowing what they were doing working on them. Id say if it has lasted 17 years it probably was a good one just make sure to do your due diligence and have a qualified technician inspect it, one who has been an Evinrude dealer a while.
emdsapmgr
OMC was headed for bankruptcy when they were trying to launch the Ficht direct inject engines. The problem Fichts were the 60 degree V6 models made by OMC. The 90 degree big blocks were ok. They issued a number of field fixes, including some upgrade kits which were to be installed no charge for the customer. These were a problem up through the 1999 model year. Many failed and it was a PR disaster for OMC. The 2000 models were produced by the new owner, the Bombarder corp. The Bombardier models ran just fine. I'd stay away from anything 1999 and older. You might be able to contact Bombardier and have them run the serial #. That might tell you the warranty repair service history of the unit you are looking at. Any field fixes still open on your prospective engine is not the resp of Bombardier, so any updating will be on your nickel- if the parts are even still avail. It is true that some did run ok right out of the box. But a large % failed once, or twice and never ran right. I know of a customer that had two powerheads repl by OMC. When it failed the 3rd time, that was it. Customer had to junk the engine as OMC would do no more repairs on it.
jimmbo
This kind long winded...
The Ficht engine was mechanically sound, the technology was sound, mostly. The problems occurred because there wasn't much experience/knowledge regarding how the combustion process differed from regular engines. Old style 2 strokes burned lots of oil and gas and make a dirty exhaust, and lots of soot or carbon. It would gum up rings and leave deposits, but mostly it was a soft carbon which could be washed away. Also all 2 strokes, didn't matter if carbed or Injected, sent gas/oil/air through the crankcase on the way to the combustion chamber. This oiled and cooled the rotating parts and the underside of the piston. Direct injection comes along. Now only air is passed through the crankcase, no fuel mixed with oil, so no cooling in the crankcase, and oil, and very little at that, is now injected into the crankcase. The oil is what contained the detergents needed to keep a 2 stroke clean. During certain operating parameters, a Direct Injection engine, can run on a very tiny amount of fuel. Idle and off idle, up to about 1700 rpm the inject timing and injector aim permitted a very lean stratified charge type combustion. Unfortunately these conditions also created a very hard type of carbon to form. This carbon would build up under the rings keeping the rings from being able to expand/contract. The lack of gas/oil to flush the carbon out added to the problem, and these engines would score pistons from stuck rings. Another part of the problem was these problems were occurring in an RPM/Load parameter that wasn't even considered a risky range. Evinrude, having built 2 strokes for almost a century did most endurance testing at WOT, the common sense was if it survives, say 2000 hours @ WOT, it would last 10,000 hours at 1/2 to 3/4 throttle. Updates were done to the Mapping of the fuel injection, to timing. New cylinder heads, with a fuel deflector to reduce sooting., even entire powerheads were changed out. Special oils and Detergent Additives(Carbon Guard) were introduced and recommended. The later Ficht Ram and now E-tec seem to have that under control.
Automobiles with Direct Injection are currently going through similar pains. These auto engines are carboning up in areas that never occurred with a carb, Throttle Body Injection, or Multi Port Injection systems. One is carbon building up on intake valves, rarely occurred in older engines , even if you had bad valve guide seals. The gasoline kept them clean. They also tend to soot up the tail pipe exits. On Direct injection engines with turbo chargers, if someone uses Combustion Chamber Cleaner, the harder carbon has been known to destroy the turbine. The only safe way to solve the carbon issue is replace/clean the cylinder head. Fine when done under warranty... however warranties do expire....
Back the Ficht. I had a 1998 150. It was carboning up. it had the gambit of updates, remapping, cylinder heads, complete Ficht Ram powerhead. During the winter after the powerhead I saw an I/O I liked, Trading up was gonna cost me about $9000. Well my Ficht was coming out of warranty that coming season. I figured if the powerhead were to croak it was going to cost about $8000(can) for a new powerhead that could croak again. For an extra $1000, a new bigger boat, new engine(lot more power) 4 more years warranty. So I traded. During the inspection of the Outboard, there was an (interesting score) in one of the cylinders, the powerhead had only 49 hours on it. A warranty claim went on that powerhead so it didn't cost me on the trade.
82rude
The brp era ficht,s were improved over the omc era disasters.I personally know a dealer that was omc forever.Called him up about a motor one year and he says we don't sell omc anymore were now merc.So my question was why,his answer I can still remember to this day,Phil I cannot with good conscience send a customer out on the water with one of those pieces of junk.Sure some are good but way way to many are junk .I use to see many fichts around now their all gone and its a extreme rarity around here to even see one atall.The same era 4 stroke Johnson and evinrudes are still plentiful just the 2 stroke are rare.Omc was in financial trouble at the time and combined with the superfund issue ficht was the final nail.Thank god for brp,i find it hard to imagine our hobby without evinrude.
mtlendy
Thanks for the good insight to all that posted . I went with my gut & passed on the boat.
