1999 Evinrude 15hp will not take throttle
IAV82
I have this 15 hp Evinrude. Ive cleaned the carb. (maybe mot good enough) this thing runs at idle perfectly. I could not ask for better. But when i begain to add throttle, it boggs out like it starving for gas. If i give it just a quick choke it continues fine and run great.. Its just when going from idle to a higher rpm that it boggs out..... What can i do to prevent this?
Joe Reeves
The high speed jet that screws into the bottom portion of the upper body is somewhat clogged..... carefully clean it with a piece of single strand wire.
IAV82
Thanks! I cleand it and used gas welding tip cleaners to clean those. It ran fine the first time i took it to the lake the rhe second time is when the problem started. I'll try it again and maybe put a in-line fuel filter. 👍
