1999 Evinrude 115 hp FICHT EMM Went Bad - replace?
jfsegar
So I've posted a few others times about possibly having a bad fuel pump or stator. Tried fixing a few things myself with no luck so I took it to an outboard repair shop that specializes in Johnson and evinrudes. After keeping it 2 weeks they called and said I need a new EMM. They said a brand new one is $1950! I know these things can be sent out for repair for far less. I have a few questions though. Would you guys spend the money to fix the EMM or sell for parts and buy a different used motor - non FICHT. I know someone selling an early 90s Johnson for $1500. Also I've seen a lot of used EMM on eBay and wanted to know could I purchase one of these to replace mine? Would it have to be sent off somewhere to be "reprogrammed?". I know a lot about carbed engines but these injection ones are new to me. Kinda wish I had a carved one right now. I love my boat that the engine is on I'm also not sure how many hours are on the engine. The engine looks like it is in great shape - just runs hot and shutsdown after 10 minutes. Any thoughts would be appreciated.
woody66912
Re: 1999 Evinrude 115 hp FICHT EMM Went Bad - replace?
You would have to send the used emm to DFI technologies with your ser# off the injectors that are installed on your engine and have them install the coefficients. plus you don't know what you are getting from e-bay. and the fact remains that this engine will most likely $100.00 dollar you to death in the future. I'd steer clear of keeping the dream alive with this old FFI.
boobie
Agree + 1 !!!!
jfsegar
I was thinking just change out the motor. I found an 86 Johnson 150 HP that looks to be in great shape. no control or mounting hardware. Anyone know if I could use the controls cables and mounting equipment from my current FICHT to fit the older Johnson? Thanks for the replies.
boobie
You should be able to use them with some wiring harness adapters. Check with your BRP dlr for the part #'s.
woody66912
I just checked you need the harness that goes from the red plug to the MWS system. Part# 176344, It's over $200.00.
jfsegar
Yikes. I could probably find some controls for around that price. Thanks for the research. A lot of the outboards I was looking at come with controls so I may try that route and just sell my controls separately or with the engine.
woody66912
Good thinking. Hope everything works out.
gscaton1
Just sent a EMM to DFI, I have a 2000 200HP, the cost was 831.00 plus shipping, 1 year guarantee but I heard they do about 30ty upgrades, They are suppose to be very good.
jfsegar
Thanks for the info guys. I have found a few motors and want to get your opinions.
1. 1984 Mercury 115 hp. Guy says it was just rebuilt - pistons, new powerpack, everything, and he has receipts. Will sell for $1500 with controls.
2. 1986 Johnson 150 - will trade for my ficht motor
3. 1988 Evinrude 115 xp - will trade for my ficht motor
Motor 2 and 3 I would not be able to water test since they are off the boats. He does have the connections so I could use my current controls. Motor 1 I could test drive.
Any thoughts?
woody66912
SON of crap I just typed out a post. GO to reply and booted off DAMMM.
woody66912
Well if I were you I would do the 1988 , are you sure that's a xp, I don't recall a 115 xp, but do a compression and spark check, and don't forget to check the gear lube.
jfsegar
Whoops. Sorry I meant that It was a 88 evinrude 150 xp. The guy said it was off the boat and could only show me it runs on a stand. I could do the compression test and just know that I would probably need to put some money into it.
I'm thinking the merc may be the best deal if he has paperwork showing everything was redone and I can water test it. Although trading for the other motor would be nice as trying to find a buyer for the FICHT motor needing the EMM may be tricky.
boobie
What ever you do, just get out from under that FICHT.
