1999 e70pl4ss no telltale
Greg.D
This engine was displaying a tell tale here after referred to as TT. It now longer displays TT and I did manage to get to show TT at one time using a plastic zip tie bit it stopped shortly after. the TT displays itself right at the exhaust port on the back of the engine. I assume that there is a hose that leads from the block to the exterior TT but am unable to locate it. Can anyone help me locate this so I can clean the entire TT unit?
Thanks so much.
interalian
^ I was thinking that too, but wouldn't that be hot water? Telltale is usually cold water sourced between the pump and the hot stuff.
oldboat1
Good thought, interalien -- unable to locate an elbow or any other likely spot on the parts diagrams.
Come to think of it, though, aren’t the elbows usually on the exhaust manifold?
interalian
If the water goes to the exhaust manifold first, and comes from the bottom, it would be a cool port. Never worked on a 4-stroke OB...
