Hello all, this motor idles great and revs fine in neutral. When in gear it barely chugs along, almost dies and backfires through the carb from time to time. I have had the carb cleaned and fuel lines replaced. The odd thing is that the other day while under way it all of a sudden ran fine for about 15 minutes. When I dropped the throddle down in the harbor it returned to the same issues. It seems like the fuel/air mix is rich when its acting up. Since it did run fine for a while it seems like if might be something in the EFI...loose wire or bad injector maybe. EFI seems impossible to troubleshoot but I hunting for suggests for what it could be...thanks, Dave
