milehighboater
- Jul 28, 2009
- 235
I have a 1999 75hp 3 cyl 2 stroke (one that was built by merc) that doesn?t like to idle around in gear that much. I can leave in running at idle in neutral for hours but when it is in gear ie. when I am in a no wake or trolling it will bog down and die. It will run for about two minuites in gear before it bogs down and I can bring it back momentarily if I hit the key in to choke it but if I don't throttle up it will die. The bulb goes soft but never flat and the motor will start up without much problem with a bit of throttle. I have recently replaced the fuel filter, coupling and bulb. It is on a tracker 175 with a permanent tank so there is no fitting there, and the tank has a breather line going to the fuel fill that doesn't appear to be blocked by anything either way there is no change when I run it with the gas cap off (I was checking for a vacuum). The last thing I was going to replace was the fuel pump diaphragm but wanted to see if I missed anything. I brought the boat up from Missouri about 6 years ago had it re-jetted and I don't think the guy did a very good job tuning the idle mixture, any good procedures for that? I think the carbs are good and clean, there is no leaks I can see and I have winterized/decarbed it about once a year. After it gets above about 2000 RPM she runs like a champ, like I said earlier it will start quick and idle in neutral for hours. Anyone that would like to throw around some ideas would be much appreciated. Thanks.
