1999 70hp oil in carbs
tinboat257
Ihave a 1999 70 hp Johnson , a nice running unit , except when the boat sits for an extended period of time(a month or so) the oil will build up in the carbs and has to be drained before the engine will start..what can I do to prevent this, besides get out in it more (lol!) Thanks guys and thanks for the board.
Bill
ob
Re: 1999 70hp oil in carbs
Two things I know of that can cause this.A leaky seal between the oil and fuel portion of the VRO/OMS pump unit is one.The other is a defective vent on the oil reservoir which builds up pressure particularly when ambient temps increase.Had the same issue for a spell before disabling the VRO and using the pump as a 50:1 pumper.It got really annoying having to clear all of the smoke on initial startup after a period of setting out of use.
tashasdaddy
i had the same problem, with my 2004 50hp on my pontoon. the oil tank was higher than the carbs. i finally went to premix also.
