Re: 1999 50 h.p. Mercury Compression
That is a mechanically healthy engine.
Don't know where you got the 120psi number, but it wasn't from Mercury.
Differences in guages, engine temp, battery voltage, preparation and technique can make as much as 50psi difference in measurement.
That is why no maker sets specs on psi. They do set a comparison spec. Usually +/- 10% span among the cylinders.
Your span is well below 10%.
