1999 5.7 gsi volvo penta. knock?
patbarb
I have a 1999 four winns vista, motor sounds great but when I run under a load above 2800 rpms it makes a knocking sound in the back. Any ideas
CV16
Is it a motor knock or in the out drive? You might have to have another person drive so you can isolate the problem. Get a mechanics stethoscope and see what you can find.
patbarb
I can not tell if it is engine knock or in the out drive. Had a mechanic ride with me and he could not pinpoint the problem.
Pull the drive and run the motor on a hose hooked to the raw water pump
jimmbo
Does it knock at that rpm in neutral, or just in gear under load? Perhaps if the mechanic had access to a dyno, it might make it easier to locate the noise. Quite possible the CV joint is binding
