1999 4.3l: Something loose that shouldn't be...
kevC
I have a 4.3l that developed a rattle over the weekend, or at least I noticed it at the weekend.
When I had a look, I could see that there was something loose and spinning behind the main pulley that I'm guessing shouldn't be.
Looked it up online and I think it is the harmonic balancer.
Does this need replaced, or can it be repair (re-attached) and what else should I now worry about (oil seal etc)?
thanks
Bt Doctur
Re: 1999 4.3l: Something loose that shouldn't be...
Replacement only.
809892T BALANCER-HARMONIC
Ayuh,... That's a Major issue,... Don't Run it,... Replace it....
kevC
Thanks for the response.
Is replacing it a big job, ie expensive?
If it may have caused some damage, what should I look out for?
Ayuh,... It takes a Puller to remove it,+ a press to install the new 1...
BG BOATER
Hi KevC.
My name is Bruce and I have worked at Autozone for the past 24 yrs. Autozone has a loaner tool program that you can put a deposit on a puller and installer to replace the Har. balancer. Yes , replace the seal when you take it apart. Have fun , Bruce
kevC
Thanks, but I'm based in Ireland.
I've only just got this boat and it was just back from a service, but I guess this could happen at any time?
Is it an indicator of anything else, age, abuse, neglect?
