1999 25 hp merc
bullet6mm
I am trying to drop the lower unit to change the impeller but I can't get or figure out how the shift shaft comes apart...
bullet6mm
Re: 1999 25 hp merc
To everyone out there thinking "what a moron" after studying the blow up of the parts list from mercury whomever took the lowere unit off before me turned the retainer backwards so I hade to take the impeller housing apart before droping the unit. I then found ou that "they" had installed the impeller wrong along with leaving out two of the washers.
will941s
Re: 1999 25 hp merc
You need to find another tech! Better yet....you did it once, thats half of servicing your motor. Now just replace the lower unit oil, plugs, t-stat, and clean the carb and you can do your own work.
