1999 24 volt evinrude trolling motor
Ranger481
How do you adjust the tension on this motor so it does not fold under the boat when you put the motor on high ?
Silvertip
Honorary Supreme Mariner
Are you talking about the motor "tilting" (fore & aft) under the boat or "turning" (right & left). The tilt mechanism (series of notches with a pin) that allows adjusting the "tilt" of the motor may be broken, pin missing, etc. If the motor tends to flip right or left on high speed, then that requires "tension" adjustment. Adjust the tension screw.
