1999 200 OceanPro Question
Jnjwest
The other day I was poking around under the cowl to see where the fuse for the engine was. I moved 2 wires, and they came unplugged from a white socket just in front if the electronics box on the port side. When I plugged them back in, I noticed that there was a 3rd clip like the other two I had plugged the wires back into. I could not find another loose wire anywhere, and once I had the other two plugged into their correct locations, motor started right up and seemed to run fine on the ear muffs. If anyone has one of these motors, could you check to see if the 3rd clip (middle one) has no wire attached to it?
Thanks,
John
Pictures are sideways. Right side should be bottom.
175se
Re: 1999 200 OceanPro Question
I do believe that's the connector for the vac. switch, I don't think it goes under the cover, I believe its on the fuel bracket.
