laguna freak
- Jul 25, 2007
- 5
My check engine alarm began sounding last weekend. It was only at idle or low throttle position below 2000 rpm. The alarm would quit (after 10 seconds) and light extinguish after reaching 2000 rpm but would re-initiate again at low throttle position. I ran the self diagnostic and the codes are: 13, 22, 43, 47, 49. Expressing circuit issues with the TP sensor, WT switch, WT Sensor, and AT Sensor. I had no trouble codes prior to this and these codes would not clear thus they are hard codes.
I checked all connections, wires, etc. and found no visible evidence of corrosion or damage. All fuses in the distribution/relay panel are intact. Because all of these codes seemed to show up at one time I suspect either a problem with the System Check Gauge or the EMM. My dealer does not have a system check tester and said I could by a new gauge to test the old gauge. Obviously I don't like that idea much
. Currently my alternative is to take it to my local dealer and have him run the diagnostic program for about 1.5 hrs labor.
Does anyone have any experience that could shed some light on this issue?
Does anyone know where I can get a System Check Tester?
Does anyone have experience with re-building the EMM? Can you recommend a re-build company. My dealer doesn't like DFI anymore and has suggested if necessary that he would send the EMM to Bombardier.
I appreciate the help. If Sal DeMercurio or Sea Horse reads this, I would certainly appreciate your feed back as well.
Thanks,
LF
Thanks,
LF
