1999 150 johnson fuel primer valve position
WrestleSmart
There is a fuel primer valve and it can be rotated about 180 degrees. What position should it be in for normal operation it is located at VRO?
The red lever should be in line with the proimer body.-----With the motor running it should be easy to determine where it should be as well.----With the lever in the wrong position too much fuel goes in and motor will run ruff.-----In the correct position motor wil run smooth.
