Landshark93
Thread starter- Joined
- Apr 27, 2023
- 26
Hey guys I’m having issues with my 115hp evinrude ficht model # E115fpleen
Bought the motor on the cheap with the impression that the #4 injector was the only bad thing but I have everything hooked up engine has spark has good compression everything seems to be working but the engine will not fire not sure what the issue is I have it on a stand not a boat only things that are hooked into the harness are the key switch the oil tank and I use connectors to complete the neutral switch
Engine will not start has spark and good compression and the #4 injector is getting hot for some reason and will not test right on the ev diag the other three are good and also I switch the #4 injector out with a different one bought off eBay and same thing it’s doesn’t test right like the others
Any help would be appreciated
