thesweetrelease
Thread starter- Joined
- Mar 2, 2014
- 69
hi guys I'm still having the stall issue when I put the engine back into idle from say from 1,200 rpms to idle . I checked all the sensors and all is well. today I really went over the engine and found two things.one the bottom starboard sparkplug does not have the heavy carbon as the other three plugs. these are new plugs. it was alittle "wet" and had some carbon on it but not much. I took it out and cleaned it and put it back in and started the engine and let it run for 5 minutes. took it back out and it had some carbon on the tip and was wet around the center electrodes. the other plugs were the same,heavy carbon. second is when I was running the engine I noticed on the port top head a very little bubbling of fuel around the top where the gasket is. I did a compression test again and all came back 120psi. not sure if any of this would cause my issues ,but figured I'd see what you guys thought ,thanks.
