1998 Yamaha Waverunner XL760
Luketarheel
When I try and start the jetski all I get is a click in the electrical box. Battery is fully charged. Any ideas?
indy440
bad starter?
I had a 98 xl760 for 4 years and just sold it this spring. i loved it.
Jeff Walkowiak
check the solenoid and the ground cable from the engine to the battery also be sure the engine is free to turn over, Often after sitting for a long time the pump liners swell and lock up the impeller this keeps the engine from turning over and many a person has replaced a starter just to learn the pump was frozen. It Is a very common issue with any pump that has an aluminum housing and a stainless liner due to dissimilar metal corrosion under the liner.
