1998 Yamaha C90TLRW Battery x-connection
danoammo1
I Accidently crossed terminals on the battery. The black ground wire was damaged at a few spots under the dash, but mostly near the control. I replace the damaged ground wire and checked all connections. I have power to dash and accessories. I also have power with the ignition switch on lighting the dash, but no click or anything at the motor. My test light shows continuity on yellow and red wires at the controller, but no test light at kill switch closed. The neutral switch; test light on with ignition switch at start position and off at on position. That's about as far as i've gotten, I haven't made it aft to the motor yet. Is the kill switch bad or is there something else I could try before trouble shooting the electrical on the motor?
danoammo1
Re: 1998 Yamaha C90TLRW Battery x-connection
If the starter relay is bad, does that hinder the operation of the T&T solenoid?
