1998 Twin Yamaha 130 2 Stroke Impellar Installation
Robert_T
Just a quick question as I have searched for twin motor installation and can't seem to find anything. So my question is this: If you have twin outboards and are installing the impellars I see that you rotate the shaft clockwise on the motor while pushing the case over the impellar. Is this the same if you have Twin Motors or do you do counterclockwise for one? I ask this because doesn't one propellar spin differently than the other causing the motor to rotate opposite or is that all done in the transmission? It may be a silly question but can't find the answer. Thanks for your advice.
99yam40
Re: 1998 Twin Yamaha 130 2 Stroke Impellar Installation
the motors turn the same direction, it is the lower unit that changes the direction of the prop
