1998 ox66 running rough and spitting
Hurtknee04
I have a 1998 ox66 and when I try to idle it spits an pops and even dies sometimes. I have changed the three low pressure pumps, vst filter, water separator filter, fuel filter in cowling, cleaned the O2 sensor, and declared the engine. I also checked the fuel pressure and when the key is turned it is 36. Under a load at the lake it varied only 2 or 3 psi. I really don't know where to go from here any help would be great.
99yam40
Not sure what declared the engine means
pull the injectors and have the tested and cleaned
