1998 ocean runner 150 misfire
Status
Not open for further replies.
Fisher_12
I have a 1998 jonhson ocean runner 150, I was going across the lake with the throttle opened up when it got a bad misfire, so I took the motor out of gear and it seemed to be running fine, it went back into gear fine but then if I gave it any throttle it died out. It would start right back up and idle and go into gear fine, but if I gave it any throttle it would die. I have replaced the fuel filter and the spark plugs, and it will run fine for about 10 minutes (or until the motor warms up?) but it still ends up getting a misfire and dieing out. Just wondering if anyone has any ideas on what else to try?
sutor623
Have you verified that your temperature alarm is working properly? If not you can check the temp switches on both heads by disconnection the tan wire from the temp switch and grounding it to the block. You NEED to make sure you arent overheating. Do you have a compression guage? If not go to an auto parts store and get one for $30 and check cold compression on the motor. Make sure you didnt blow a head gasket, seal or worse. Report back when you figure this out.
Is the fuel primer bulb staying hard while running? If it is getting too soft it may be a fuel pump issue (which would be my first guess here.)
If this all checks out, you may have an ignition system issue. Ignition systems seem to be intermittent, and fail most often when they are hot or operating. I wont start digging into this until you check the mechanical function of the motor.
SparkieBoat
test your fuel pump by disconnecting the hose going from pump to carbs and turn motor over, fuel should come out in fairly strong spurts. my bulb gets soft while running the motor because the fuel pump sucks the fuel and the fuel line is in a negative pressure.
Fisher_12
The primer bulb does get soft, while the boat is running and after it has sat for a while. It also has to be primed before it starts after its sat for a while
Status
