1998 Ocean Pro 225 Lower Unit
SWFL Dan
Hi guys. Hoping someone could answer this question...I currently have a 1990 Johnson 225 VRO (model# or Serial # not available) that needs more work than I have the time for, but I have the opportunity to buy a 1998 225 Ocean Pro that'll bolt on, ready to go. The kicker is, the '98 O/P has no lower unit. Will my 1990 L/U bolt up to the O/P or are there differences that'll force me to purchase a L/U for the Ocean Pro?
Thanks!
Faztbullet
The 1990 driveshaft will be about 1/4 shorter than the 1998 due to different crankshaft in motor but it will bolt up. Make sure you get the control box as the 1998 uses deutsch connectors not round plug, if not you will need to buy adapter harness.
