1998 Mariner 6hp
Nipper
Hi folks,
I need a little help please....
1998 Mariner 2 stroke (serial 0G668579)
I want to replace the stock propeller with one just like it. Number on prop hub is 48-828156-9 Google/parts selectors not finding this number.
Also need both drain plug gaskets for the gear case (I think they are different)
I need the part numbers for these 3 items. :confused:
Thanks!
carholme
Re: 1998 Mariner 6hp
Your s/n comes up as:
MARINER - ( 6 H.P. (1998 ))
Serial No: 0G668579 Model No: 7006201GD
Parts Listing for model 7006201GD:
6/8/SAILMATE 9.9/SAILPOWER 15 H.P. - Mercury, Mercruiser, Force, etc. Parts Lookup
For the drain plugs, see items 4 and 9 under GEAR HOUSING (DRIVE SHAFT)(2.00:1 GEAR RATIO)
For the prop, see item 59, p/n 828156A12 under GEAR HOUSING (DRIVE SHAFT)(2.00:1 GEAR RATIO)
The -12 is just the upgraded p/n for the -9.
If you would like the service manual for your engine, send me a PM with an email address.
Gerry
