1998 Johnson Oceanrunner 200 fuel problem
clctalking
I have a Johnson Oceanrunner 200 that will start but not stay running. I have changed the bulb and checked for leaks (no leaks). It is cold natured, but does start. It runs great for a minute, but dies when it runs out of fuel. if you can keep pumping the bulb, it will run fine.
Chris1956
Honorary Supreme Mariner
Did you check the main strainer under the airbox for gaskets that are installed correctly? Also, not sure if that motor has a vapor separator, but if it does, make sure the vapor pump and the separator cover gasket are sealing, as well.
