1998 Johnson 70 hp correct temperature
moquehue
Hello everyone from Argentina. I have a Johnson 70hp 1998 which works very well. But I have a doubt about the temperature because when you put your hand on the cover where the thermostat is housed it feels quite hot. I have measured the temperature at idle for several minutes and it does not exceed 60 - 61 degrees celcius. Is this correct? No overheating alarm has sounded and the flow of water observed is powerful. You who think about it, is working at the right temperature? The temperature in the cylinder cover and the gas chamber feels colder. From already thank you very much, greetings
