I'm having two issues with my motor. The tilt trim motor works fine when the engine is off or in neutral and when the engine is in gear it doesn't always want to go down. I have new seals in the pump but didn't replace the motor. I just found a disconnected ground wire on the ignition assembly below the two relays for the tilt trim. It was under a missing bolt holding ignition assembly to the engine. It was a bear to get in but it's grounded now. There is three bolts holding this on and this one is the lower of the three. The tilt trim problem has been happening since I got the boat a year ago but recently I blew the main fuse at the back of the motor. I replaced the fuse three times now and went over the whole wiring harness and couldn't find the source. I added electrical tape on a few things but I'm not confident that it's fixed. Any ideas would be greatly appreciated.
Thanks
Thanks
