1998 Johnson 225 not going fast
Countryboy90
Hey y'all,
I have a 1998 javelin 409 with a Johnson 225 Venom. The boat drives amazing and the motor purrs like a kitten, however I cannot seem to get the boat over 45 mph. I have tried trimming the motor up as far as I can safely get it and it will bring it up from 40 to 45 but that about it. All compression of the cylinders is right at 105-107. Everything that I have read says this boat should run 65 to 70. Any suggestions?
ob
Did it ever run faster than it does now since you've owned it? What RPMs are you getting at wide open throttle? What style and pitch prop are you running? What type speedo are you measuring speed with?
Countryboy90
I just bought the boat about three weeks ago and this is my first real bass boat and it got up to the same speed when i tested it and everytime i have taken it out. The shop that looked the motor over before I bought it said everything looks fine. I am running a 4 blade Renegade stainless prop right now. I have to replace the tachometer cause it doesn't work. The Speedo on the boat and my GPS both say about the same. Is it possibly something to do with the hot foot pedal?
ob
Best to get a tach setup first and then go from there. Everything else would just be guess work without knowing what rpms you're turning at WOT. If top end speed is your primary objective , a four blade prop is not your best option as it is designed for better hole shot bite coming on plane or running in shallows. I believe your engines recommended wide open throttle operating range is 5000-6000. For maximum top speed, prop it to run at or near the upper end of this range.
