1998 Johnson 150 - TILT/TRIM issue...
dldoolit
Hope everyone is having a great summer!
This just happened this morning. I leave motor (J150elecd) trimmed all of the way up as it sits in a slip. Went to trim down, heard trim motor turning - no movement, but sounds normal. Turned the manual release - motor lowers. I go about my day with no problems. Trim works fine, up, down - no problems. Dock boat - trim motor all the way up. Same result as when I first tried to trim down this morning. Like it's stuck or locked... Is their some kind of locking mechanism that I am missing? Something that the Manual Release screw would over-ride. Or is this something more deeper and ugly?
Any help with this matter is greatly appreciated!
Thank you for your time.
Doug
There is a manual lock on the transom bracket. However, if the motor is trimmed all the way up, the motor is pretty well balanced on the transom, and the mechanical advantage to trim down is minimal. Have someone lean on the motor and then try to trim it down,
dldoolit
Thanks for the response, Tried leaning on motor, but still no movement.
Fazt, That motor has two components for manually locking the motor in particular tilt positions. The first is the flip down trail lock arm, which can be used for trailering. The second is the Tilt lock lever on the tilt pivot rod.
dldoolit
James R -- Oil level is good.
I am curious about the "tilt lock lever" though. I'll have to look that one up.
Faztbullet
Those do not lock the motor in place only weight and hydraulic pressure does..1991 was the only year I remember a actual lock and it is on trailing arm.
dldoolit
PROBLEM SOLVED.... First,I want to thank everyone for their feedback. helpful, and led me in the right direction. After much searching online, different forums and youtube videos I have the answer. Even though my oil was at the correct level it was still "bad" or "old" oil. If anyone ever has a problem with their motor locking in the up position or bouncing of motor when lowering, purge and bleed the old oil from the tilt/trim and replace with new. Be patient, I must've run the tilt up and down a couple dozen times purging/bleeding the old oil out and filling with new oil. Engine no longer locks when tilted up and no more bouncing when lowered. very simple and cost effective fix.
Doug
