1998 Johnson 150 Check Engine Light
breakaway
I had a water pump put into my engine last fall and there is an exhaust leak. My mechanic says that its probably from the exhaust housing not sealing properly. At the same time,The Check Engine Light comes on which means a fuel restriction. Could the low back pressure from the exhaust leak cause the vacuum sensor to signal a fuel restriction?. After reading my Clymer manual, I see that the VRO fuel system is based on pressure in the crankcase. The light stays on even after I turn the motor off and then just turn the key to the on position. I also unplugged the wiring harness from the sensor but the light stays on. Any help is appreciated.
