1998 Johnson 115 one cylinder not firing
cspires20
So my boat was riding fine for awhile. Then it got to where I could not put it in gear because it would bog down and shut off. So I cleaned both carbs and replaced the fuel pump. Now I just noticed that one cylinder is not firing. I tried switching the coil packs around but that did not help. I can see a blue spark going to the plug when I check to see if its firing. But the cylinder does nothing when I remove the plug wire from the plug while the boat is running. I'm thinking it might be the power pack. I don't have any experience with this sort of thing. Any help would be appreciated. Thanks!
Honorary Supreme Mariner
????----You indicate that you have spark at the bad cylinder but it is not doing anything !!.----So do a compression test.---Perhaps a carburetor is plugged.---Perhaps there is no crankcase compression.----Just do or have a shop do a compression test !!-----Doub that a new ( $$$$ ) powerpack will fix this since you indicate that it has spark now.
cspires20
Ah, I understand now. Thank you! If the compression is bad on that cylinder, does that mean it is most likely shot? We just had our motor re-bored and had new pistons and everything replaced about 3 years ago.
Only by testing and gathering the facts on your motor can you make progress.---A new power pack is $$$$.----A simple compression test costs mere pennies in comparison.---If compression is good then you look at fuel systems.
cspires20
Okay so the compression is good on that cylinder. It appears that the cylinder is just not getting any fuel. The fuel pump is brand new and the carb's both just were cleaned and soaked the the carb cleaning acid. They were just rebuilt last summer. What else could be stopping fuel from getting to that cylinder??
Model # of your motor and which cylinder is not producing any power ?
cspires20
Thanks for all your help racerone. I've taken it to a mechanic for him to look at. I appreciate all your help!
jakedaawg
I am gonna hazard a guess that your engine cover latch is grounding out the lower plug.
