So my boat was riding fine for awhile. Then it got to where I could not put it in gear because it would bog down and shut off. So I cleaned both carbs and replaced the fuel pump. Now I just noticed that one cylinder is not firing. I tried switching the coil packs around but that did not help. I can see a blue spark going to the plug when I check to see if its firing. But the cylinder does nothing when I remove the plug wire from the plug while the boat is running. I'm thinking it might be the power pack. I don't have any experience with this sort of thing. Any help would be appreciated. Thanks!
