1998 force
crl97a
I have pulled the lower unit ten times. Each time I have mated the shift handel to the gear on lower unit. tried the scotch tape no luck. Still get the same results.
JB
Re: 1998 force
crl97.<br /><br />First: Go to and read the "Suggestions for new posters" linked above.<br /><br />Second: Go back to your original post and add the information any helper must have to be able to help you. You have not identified your engine or whether you are using a manual.<br /><br />Third: The number and quality of helpful replies you get depends on the clarity and readability of your question to someone who has an answer.<br /><br />Last: Please do not post a new topic to continue an active topic.<br /><br />Thanks for your cooperation. :)
