Re: 1998 force 75 hp Stator
Sorry about that, forgot that the 1998 75 HP only has one carb. This is the gasket/bolts that I'm talking about.
Gaskets 4 and 7 in the diag. below. The bolts that hold the adapter, item 1 in place.
Mercury, Mercruiser, Force, etc. - FUEL INTAKE SYSTEM - FORCE 75 H.P. (1998)
Idle speed mixture screw should be a minimum of 7/8 to 1 turn out from lightly seated. Usually in the neighborhood of 1 1/4 - 1 1/2 out. Every motor is a little different.
Might also do a compression check.
What spark plugs are you running?
Yes the By-Pass cover are the 3 almost square covers, of which one has the fuel pump mounted to it. You can usually see some evidence of fuel/oil leaking around the edge of the cover if the gasket is bad or not torqued down.
Haven't had any issues with the terminal block method in the 5 years since I modified mine, or any others that I've done. The older motors used terminal blocks for all the electrical/ignition system connections. Just use good quality components, not the cheap stuff made who knows where. Here's a picture of one that I did years ago (yellow box) with just a two position terminal block for the battery charging wires. Still looks the same as it did when I first put it on. No corrosion and no evidence of overheated wires.
Checking trigger while in the driveway with the motor on muffs using the timing light and marking the flywheel at TDC for each piston is another way to check the ignition spark. If it's firing when it's supposed to then the trigger should be OK.
