whblaylock
Thread starter- Joined
- Sep 6, 2005
- 46
What would cause the fuel system to lose pressure and collapse the primer bulb? Spent several event free hrs on the lake and the mtr ran great. Mtr just stopped running and I discovered that the primer bulb was not just soft with no pressure but was collapsed. I played with it trying to get some fuel to the mtr and that worked for a few hundred feet. played around again and was able to get some fuel in the mtr and went another 100'. Tried again and the bulb picked up gas and pumped up tight and from that point it ran fine. I inspected the fuel lines and could not find a leak. Had a qtr tank of gas. Would trash in the tank getting into the pick up tube cause it? Thanks. WH
