1998 Ficht 150 WOT
Datsbp
Hi, I have 1998 Evinrude ficht 150 Ocean Pro on a Crestliner Sportfish 1850. I've had this boat for approximately 3 months now and I believe it runs great. My question is why isn't my RPM higher at WOT. With a normal load it runs at most 5100. I've read in other forums I should hit at least 6000. I know most will say it's over propped but I'm not sure that's the case because it has a hell of a hole shot. I mean the engine never lugs at all and will literally throw you out of the seat when nailing the throttle. It almost seems like I would have to adjust the throttle or something to get more RPMs but when I looked it does seem like it is going full throttle. So my thought is maybe software or I don't know. Please help
Rustywrench
That motor is rated 4500 to 5500 RPM WOT. 5100 is in the middle of the band. Not necessarily a bad spot for the type of boat you describe. If it has the factory update kit on it then that would also contribute to it being a little less. Enjoy!
Datsbp
Thank you! I have another question if you don't mind. Does it hurt running wide open for long periods of time on that engine? I ask because I'm usually on bigger Lakes and Crossing them often so I run wide open but I don't want to be doing that it was going to hurt the outboard. Thank you
jimmbo
High Speeds are actually good for the FICHT, Almost all the problems with the FICHT resulted from running the engine under high loading at speeds below about 2500 rpm, Just use BRP XD50, XD100 or Mercury/Quicksilver Optimax oil to increase the chances for the engine to live a long life. What your WOT rpm is very dependent on how the engine is propped, which of course is dependent on boat size and hull design, boat weight, load carried in boat. You mentioned you get 5100 which is just about the middle of the WOT range, but you never mentioned what prop you are using. The 150 puts makes less than 1hp per cubic inch of displacement, which means it also has a wallop of low end Torque.
Rustywrench
No it does not! That model would actually rather run WOT than 1800 to 2200. That is the cross over point.
