1998 Evinrude 30HP got hot now wont start
coachjmwood
got hot while running, now when i mash starter button nothing happens, what do i check, motor turns when i put hand on flywheel and turn
coachjmwood
I shut off motor when i realized it was getting hot, not on its on, now nothing when i mash starter button nothing happens, how would I ck compression when motor wont turn over?
Will Bark
does that motor have a fuse in a holder near the starter? If so, check it. Can you use a rope to spin flywheel for compression test? Good luck
Honorary Supreme Mariner
???----Booster cables to the starter to see if starter still works.
coachjmwood
compression 120 120 I think its the little switch when you change gears, to put in neutral?
