1998 Evinrude 150 Performance
rdobias
Hey guys,
Over the winter I rebuilt a 1973 Mako 19 and then bought a 1998 Evinrude Ocean Pro 150 hp. It seems like boat should move a little faster with this power. With a 15x15 aluminum prop, I could achieve the max rpm at 5700 but only 34 mph. With a stainless 15x17 prop which is what I am sticking with for the time being, I got 5200 rpm and about 42 mph. With a 14.5x19 aluminum prop, I only got 4800 rpm and didn't get to check the speed. I am thinking a 15x16 prop would be perfect for rpms but I don't wanna loose anymore speed. I would think this boat with a 150 should be hitting the high 40's low 50's easily. I did replace the deck completely with 3/4 plywood and replaced the transom and it has probably more glass on it than before so the boat may be a little heavier. Still I would think I could get more speed. I'll post in the prop section too. The engine is also moved up 2 holes and I may do one more but there really isn't much spray Thanks for any ideas or tests I anyone can think of. Here is a link to the boat running with the 15x17
http://s1212.photobucket.com/albums/cc446/rdobias/?action=view&current=IMG_1026.mp4
walleye seeker
Re: 1998 Evinrude 150 Performance
i have a crestlner 18' alluminum walk through with a 135 evinrude ficht top speed 44mph at 5000 rpm. I believe your mako ways alot more than my boat. I also have a stainless prop so if you get 42 mph i would guess that is about it.
rdobias
Alright, anything that can be done to get just a few more mph?
boobie
What horse power is the boat rated for ??
Chris1956
Honorary Supreme Mariner
My 21 footer with the same power can get 37.8 MPH, downhill with the wind. Consider yourself fortunate....
