1998 evinrude 115 cylinder head torque pattern
Captain scrunch
Anyone have the torque pattern/spec for a 1998 evinrude 115? It was running poorly, wouldn't idle, felt like it was making 60 hp. Sure enough, very low compression on lower port cyl. Head gasket was GONE...
interalian
Start in the center and work out in increasing circles. I do it in three steps: 1/3, 2/3 then full torque. Re-torque after a couple of heat cycles. Make sure the head is flat before re-fitting - if required, dress the surface with medium wet/dry sandpaper on a flat surface like a thick pane of glass until surface is flat.
