1998 Bravo lll
boss434
Hi Guys,
Just getting around to reinstalling my drive and noticed two exrta small o-rings in the baggy......all others can be accounted for and installed but these two ............would they be for a different drive set up
Re: 1998 Bravo lll
Ayuh,... small is a relative term,... how big are they...
do you have the 2 on the input shaft,..??
boss434
Re: 1998 Bravo lll
hi, yeah sorry,
I've installed the square water ring, ........the shift o-ring...... the oil reservior o-ring...... and the three on the input shaft....now there's two about a haft inch round....mabe if i had takin the lower unit apart they would have gone in there??????
Don S
Re: 1998 Bravo lll
Are they actually rubber orings or fiber washers?
IS this a kit that someone put together? They don't normally come in baggies. Was it OEM parts or aftermarket. Some aftermarket kits have different things in them than OEM kits.
boss434
Re: 1998 Bravo lll
Hi
yes this was a siera kit, I mean everything fit right in place and ther was no other place that any o-rings could go soooooooooo. just woundering...maybe the water ports from the lower unit up to the top???? but I've not seperated them.
BIGALF
Re: 1998 Bravo lll
are they the small O rings for the oil plug and the oil vent plug? They should be replaced evertime you change the oil.
boss434
Re: 1998 Bravo lll
AHHH YES of course.....how stupid of me
makes to much sense now....Thanks a bunch:redface:
Don S
Re: 1998 Bravo lll
That is why I ask if they were orings or fiber washers. Be very careful, MOST drives use the fiber washers on the fill and drain plugs. Only a few used the rubber orings, and they have a groove in the plugs for the orings to set in, No groove, you should use the gaskets
BIGALF
Re: 1998 Bravo lll
I just did my Bravo III and they are o-rings.
